Leaked Back Photo: iPhone’s Next Generation Phone. True or Fraud?
Through many speculations of an upcoming newer version of iPhone 4S,  are there any truth regarding the upcoming iPhone 5? What is the legitimacy assurance behind the leaked photo of the back casing of the supposed new iPhone? Where did its source got there hands on the iPhone prototype?
Answered By 0 points N/A #143712
Large portion of the back panel is made out of metal and the remaining part seems to be made of glass. As you can see in the first image below, it gives it a two-tone effect.
The next generation iPhone will get a metal antenna band like iPhone 4 and iPhone 4S, but in case of the sixth generation iPhone, it seems to be moulded with the metal back panel
The position of the headphone jack has moved from the top to the bottom, next to the speakers.
It has the rumored smaller dock connector
The speakers grills have been redesigned
There appears to be a new opening between the camera lens and the camera flash. 9to5Mac speculates that Apple may be planning to move the second microphone to the back for improved video recording.
The front panel indicates that the next iPhone will come with a taller display but with same width as iPhone 4S and iPhone 4, which is in line with recent rumors.
