Learn About Asset Management Software Free
Hi. I would like to know about the asset management software free. What are the steps to install the IT asset tool? Also, what are the system requirements? Thanks in advance. It will be helpful.
Hi. The steps to install the asset management software free are as follows-
1) First download the .NET framework version 2
2) Then, download the IT asset tool with v1.2 and above
3) Then select the unblock option after right-clicking on properties
4) Then in the C: in program files, save the file after you unzip it
5) Run IATMng.exe after you right-click on it and then select the option run as administrator
6) Click on the configuration menu and then click on install option
7) Then click on start, then run and type services.msc. Then select DaemonIAT and then start it
To manually install the service,
1) Type cmd in the start menu and type cd%windir%.
2) Then, go to the Windows service and start the DaemonIAT service.
The system requirements are- Windows OS and .NET framework version 3.5. Hope we helped.
