Learn About The Best Antivirus By Knowing How Good Is PC Matic
Hi. I want to start using PC Matic. I am confused about its reviews though. I cannot really decide if using the software will be a wise decision or not and also about how good is PC Matic. What are its features and advantages? Also, what are its requirements? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #162102
Hi. To make it is easier for you; let me focus on the features and the advantages offered by PC Matic to make you understand how good is PC Matic.
• It uses a white list which makes sure that only those devices which have been mentioned in the list are given access to the PC making it more secure and thereby blocks the polymorphic threats
• Whatever be the security issues in software such as Java, PC Matic handles them automatically
• Generally the use of an antivirus slows down the PC. But, this antivirus does not compromise on the performance while executing
• It also provides protection against the hardware
• It also prepares reports related to the maintenance and security of the computers
Some of the features include-
• It is easy to use
• It provides security against all the modern security threats
• It cleans the registry
• It helps update the drivers
• It removes the files which are of no use, scans and removes the threats
The system requirements include-
• It supports Windows 7, 8, Vista and XP
• It requires a processor of 1Ghz or greater
• It needs a memory of 512 MB or higher
• It requires free space of 1GB or greater
• An Internet connection is mandatory for the software to function well
• The languages it supports include French, Japanese, English and many more
Hope we helped.
