diegobro
Posted on - 04/10/2017
I bought PlayStation 3 a month ago. In the beginning it worked fine but recently I have been getting an error with error code 80010514. As I have no idea what it is, can you please help me know it and its solution? Please reply ASAP.
Learn About Error Code 80010514 In Ps3.
Hello. Error code ce tells that the PS3 is facing problems in loading the disc. First check for scratches on the disk to get an idea if it is damaged. Try using another disk. If it doesn’t help then follow the following steps. Press and hold the power button for a while to turn off the PS. Again press and hold the power button until it beeps as it turns on.
Release the power button when there is a double beep. Plug in your controller and select Restore File System option. After that the PS is going to restart and show corrupted system data reading screen. After replacing these files PS is going to reboot and the error is now fixed. This should help.
Error code “80010514” in Sony PlayStation 3 means “The PS3 system was unable to read the current disc.” This indicates a problem with your game disc. If you receive this error when playing a game, eject the disc and clean the surface of the disc with a soft clean cloth. After this, insert the disc back and try again.
If this doesn’t work, try loading a different disc in the console and see what happens. In case the second disc loads successfully, your first disc is probably damaged that’s why it cannot load. You probably need to replace it.
On the other hand, if the second disc or any other disc you try doesn’t load, you probably need to bring your PlayStation 3 to the nearest Sony repair shop to service it.
