Learn About Exchange 2010 Installation Requirements In Detail.
I have Windows Server 2008 R2 running on my device. Now, I wish to install Exchange 2010 on my Windows. Does anyone know about exchange 2010 installation requirements?
If yes, please reply.
Thank you.
Answered By 0 points N/A #295040
If you are asking about the system requirements for installing Exchange 2010, then this will help you:
Directory Server Architecture
Using 64-bit Active Directory domain controllers just increases the directory service performance for Exchange 2010.
For performance and security reasons, I would recommend you to install Exchange 2010 only on the member servers and strictly not on Active Directory directory servers.
Hardware
The hardware requirements for installing Exchange 2010 are as given in the image below:
