Learn About How Do I Find Duplicate Files On My Computer online
Hi. I am a student and I use MS Office. However, at times it so happens that there are some duplicate words or images which are a part of the same document. I would like to know the steps to know how do I find duplicate files on my computer. Please reply ASAP. Thanks in advance.
Answered By 10 points N/A #122653
Hi. A software which can solve your query of how do I find duplicate files on my computeris easy duplicate finder.
It is available for both Windows as well as Mac users. It helps increase the speed of the PC, organize the files and free large space up to gigabytes. It is accurate as well and finds the duplicate files present. The steps to use the tool are-
1) Download the software from the website
2) After the software gets downloaded, double-click the software to start the installation
3) After the installation gets complete, open the software
4) On the window that appears, drag and drop the files which consist of the duplicate information
5) Then, click on the scan button to begin with the scanning feature so as to find out the duplicates
6) Close the window when complete The features are-
• Fast and accurate
• Search is advanced
• Google drive and drop box can be checked for duplicates and formatted accordingly
• The tool also protects the files against deletion
• There is also an undo button present for recovery of files
Hope we helped.
