Learn About The HP Compaq T5730 Thin Client Using Simple Steps
Asked By 15 points N/A Posted on -
Hi. I am not very known with the computer software and hardware. What are the steps to install the OS on HP Compaq t5730 thin client and also the JVM on the client? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #108587
Hi. The steps to install the OS on HP Compaq t5730 thin client require you to first select the desktops and workstations. Next, select the HP think clients option and select the model number of the client. Next, select the step by step troubleshooting following which the software issues should be clicked on. Then, click on the arrow next to the Operating system and then learn how to reinstall the OS on the HP T5730. The steps to install the JVM require you to first download the .exe file from the Internet. Next, after executing it, load the virtual machine on the system.
After the execution of the file starts, to continue further with committing the changes, first agree to all the conditions mentioned by the company. Then, the think client needs to be rebooted. After the reboot of the client is over, it should be started.
Hope we helped.
