To Learn About Hp Support Office Jet Pro 8600.
I own a Mac and I just bought my new hp support office jet pro 8600. Can you tell me if Mac supports it or not?
This printer is compatible with Mac OS X 10.5, 10.6, and 10.7. The Mac can be set up using PC. If you tried setting that up with Wi-Fi, you would face some problem. The scanner controls were not as good as with the PC.
You do not have to do anything new with the Mac, just use an updated download.
Yes, the HP Officejet Pro 8600 printer is compatible with OS X. If you have a Mac, go to HP Officejet Pro 8600 e-All-in-One Printer – N911a to download the driver. The page should automatically detect your operating system. If a different operating system is displayed, click “Change” then select your correct operating system.
For Macintosh, the HP Officejet Pro 8600 printer supports OS X 10.5 Leopard, 10.6 Snow Leopard, 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, 10.11 El Capitan, 10.12 Sierra, 10.13 High Sierra, and 10.14 Mojave. For Windows, the HP Officejet Pro 8600 printer supports Windows XP (32-bit only), Windows Vista, Windows 7, Windows 8.x, and Windows 10. Download and install all appropriate drivers and software for your printer.
Notifications
