Learn About Interface Crc Error Count In Detail.
Hello, I just want to ask if should be worried about the interface crc error count on my computer. I was using HD Tune Pro when it came to my notice.
Here’s the screenshot of the same:
I guess I am aware of the situation. What you are looking at here is your drive’s error correction rate. As much CRC errors you see will tell you how worn your drive’s magnetic disk platter is used to read data.
As seen in the screenshot, the value 200 that you see are just the amount of cylindrical errors of the drive. The Data value is the amount of total data which is lost or corrupted in block size, or a part of the platter which cannot store data.
