Learn About Junos Pulse For Windows 8 In Detail.
I want to know how to install junos pulse for windows 8. I want to use the JunosPulse VPN client.
Does anybody know the method of installing Junos Pulse VPN client for Windows 8?
Follow these steps below, and you will be able to download your desired software:
1 – First of all, download the software UCSFWinPulseClient from this link: https://software.ucsf.edu/content/vpn-virtual-private-network.
2 – Then, double-click on UCSFWinPulseClient.exe to install.
3 – Next, click on the Junos Pulse icon.
4 –After that, select UCSF Remote Access and then Click Connect.
5 – Enter your username and password.
6 – JunosPulse will then minimize to the taskbar.
7 – If you wish to disconnect, then right-click on the Pulse icon and choose disconnect.
