To Learn About Language Pack For Office 2010.
I have recently purchased a language pack for office 2010. As I am not a regular computer user. Can you please help me to install the pack on my PC?
To install your pack, follow the steps mentioned:
1. There would be a Setup program in your Language pack, run that. Download disk as normal.
2. As soon as the installer opens up, select the product you want to add a language pack for.
3. Click on Continue, stating that you accept the license agreement.
4. Later, Click on Install Now to install the Language pack. Have a check once on each of the Office applications you have such as Word, OneNote, and Outlook. They need to be closed before you start the installation.
5. As the pack is installed, your new language will be enabled, and in case your Office was in a different language which you already have in your Windows default.
Notifications
