To Learn About Mazda 6 Air Conditioning Problems.
Hello, as I turn on the A/C, the Air conditioner motor never starts. I put a gauge, and it shows 0. What can be the Mazda 6 air conditioning problems?
There can be few listed problems you can work upon.
1. Try starting the car and turn the A/C on. Run the engine few times. Check to make sure you have the buttons selected.
2. Try adjusting the climate controls.
3. From the inside of the car, try getting into the Fuse Box in Mazda
4. On the passenger side of the door, pry off the trim panel.
The chart packed in the fuse box cover should be used to find the suitable fuse. Replace it with a fuse of equal amperage.
5. Before getting to the control panel, You can try disconnecting the negative battery
6. Try removing the blow motor if that was not working properly.
