D. alvin
10 points
Posted on - 10/12/2016
Hello, I have already installed the McAfee anti-virus tool on my computer. And I am not finding it that pretty helpful. My current version of operating system isWindows8. I am trying to uninstall it, but I am not able to. Can anyone tell me if there is McAfee removal tool forWindows8?
Sibtain
To Learn About Mcafee Removal Tool For Windows 8.
To remove McAfee, you should remove it by their actual tool.
It won’t be removed completely If you try to uninstall it by add/remove features. Some of the registers may remain in the Windows database which might create problems in future or at the time of installing other McAfee products.
You may also have to deal with some problems like Freezing of your computer.
Internet connectivity.
Slow speed Error while installing upgraded version.
To find the solution from all of these problems, there’s a removal tool named McAfee to uninstall tool. This may help you remove the software completely.
