Learn About Microsoft Windows 7 Upgrade Advisor
Hi, I am a non-IT person and I don’t have any technical background. My friend has recommended me to download upgrade advisor. I would like to know about the need of Microsoft Windows 7 upgrade advisor and how could I download the same. Reply ASAP. Thanks, in advance.
Answered By 0 points N/A #288750
Hi there, Microsoft Windows 7 upgrade advisor is a software that allows you to see that whether your computer is compatible for Windows 7 or not.
It is able to scan your hardware, devices & installed programs. Also check the compatibility problems too. It will guide to resolve potential issues as well advices you what to do before upgrade your operating system to version 7. You can download the upgrade advisor directly .
Filename is Windows7UpgradeAdvisorSetup.exe
Size of file is 8.3 MB
You should run this .exe file and then install the application to your PC. Now plug in the USB device such as printer, scanner, external hard disks which you have been using frequently. After that run Windows 7 Upgrade Advisor from your start menu or from the shortcut created on the desktop. Hope the answer proves to be fruitful for you.
