I recently tried configuring my netgear router but failed a number of times. Can you please help me in knowing the netgear wireless router configuration step by step procedure. Reply ASAP.
Learn About Netgear Wireless Router Configuration Step By Step Process.
First step is to connect your modem to a port of the router and your computer to LAN port. Wait for the systems to finish booting up. Type IP address in the web browser and hit enter. Log into the router. Type admin and password and the default username and password respectively. Open setup wizard. The setup wizard is used to detect the type of connection. The router now saves the settings when you click on next. Select Router Status under Maintenance. To check your internet connection. Hope this helps.
