Learn About Pagemaker To Pdf Converter In Brief.
Does someone know about any pagemaker to pdf converter or some manual procedure of the same? If yes, please tell me how to do it?
Thank you in advance.
Adobe Pagemaker is not in use since 2004, but many users still have some cache of documents saved as .pmd files.
Not even the latest version of PageMaker, InDesign, can manage old PageMaker documents.
If you have some old file of PageMaker or you already have the program installed, then you just require installing virtual PDF printer and then print your file as a pdf document.
If you are using mac OS, you will then require installing Windows virtual machine to view old PageMaker files and convert to pdf.
