Learn About Powershell 1.0 Server 2003 In Brief.
Hi all,
I wish to install powershell 1.0 server 2003 on Windows 8 on my computer. Before that, I want to be sure about the software.
Can someone tell me about the same?
Hi all,
Microsoft PowerShell 1.0 release for Server 2003 is a brand-new command-line scripting as well as shell language designed for administration of the system and automation.
It involves more than 130 tools of command-line (called “cmdlets”) to perform common system admin tasks, like managing services, event logs, the registry, and by using Windows Instrumentation. The command-line tools are specifically designed to be simple to learn and use with naming conventions and parameters, and tools for sorting and formatting data and objects.
