Learn About Prerequisites For Exchange 2010 On Windows 2008 R2 And Details.
My friend is worried about the details of prerequisites for exchange 2010 on windows 2008 r2. Can anyone please help me knowing these details. Reply ASAP.
First way is to install office system converter and add windows components and features that are appropriate. Open powershell windows and run import-module server manager command. Set your net.tcp port service as it should start automatically if your server exchange has client access server. Again open powershell via taskbar icons and type the command set-service nettcpport sharing. Make sure the startup type is automatic. Hope this helps.
If you have Windows Server 2008 R2, here’s how to install the prerequisites for Microsoft Exchange 2010. Open powershell and run the following command:
If your server will have the typical installation of Hub Transport, Client Access, and the Mailbox roles, run the following command:
If your server will host the Client Access and Hub Transport server roles, run the following command:
If your server will host only the Mailbox role, run the following command:
If the server will host the Unified Messaging role, run the following command:
If the server will host the Edge Transport role, run the following command:
After restarting the system, run the following command to configure the Net.Tcp Port Sharing Service for Automatic startup:
Note: before installing the prerequisites, you need to prepare your environment first. Visit Preparations for Exchange 2010 Prerequisites for more information.
