Learn About The Product Key Finder Office 2013
Hi. I have lost my MS Office 2013 product key. How can I find it? What is the product key finder office 2013? Please reply ASAP. Thanks in advance.
Hi. If you have lost the MS Office 2013 product key, then product key finder office 2013 might help you find one. You can locate the product key in one of the following ways-
1) In Product key card label The key can be found inside the box or from the CD attached sticker
2) In email MS sends The key can either be installed directly from the net or from the mail that Microsoft sends you
3) In computer installation disk The MS Office software is installed in the PC beforehand and then the key is available with the installation disk
4) Product key finder office 2013 The steps are-
i) First download the product key. Install the software and launch it
ii) Get the Office 2013 serial number by clicking on get key present at the bottom of the screen
iii) The product key will be displayed in the task list
iv) Save the serial code in the .txt format
Hope we helped.
