While using visio 2000 edition I suddenly removed an item from it fixed list and now I get this as error runtime error 5 invalid procedure call or argument. Please help me out. Reply ASAP.
Learn About Runtime Error 5 Invalid Procedure Call Or Argument Details.
Whenever you remove an item from from custom properties editor fixed list you may get this error which is very common. First way to solve this issue is to try troubleshooting the problem. Try undoing all the changes made before getting this error if possible. To get rid of this issue you can obtain Microsoft visio 2000 service release 1. When you are finished correcting this error you get a message as this problem has been corrected in Microsoft visio 2000 SR 1. Hope this helps.
That is a runtime error which means there is a problem with the program. If you were creating a program and you removed something from the code, obviously that caused the error. The error says “Invalid procedure call or argument” which indicates an error in the command used in the program. Try undoing the item you deleted and run the program again.
You may also receive a runtime error when running an application not just when creating a program. When a runtime error occurs in a program, it can be a problem within application itself or the program is not compatible with your computer. If the program is running properly before and it suddenly caught a runtime error, one of its files is probably corrupt.
In this case, reinstall the application.
