Learn About Skype Standalone Installer In Detail.
I wish to query regarding the skype standalone installer in brief. If anyone has any clue about the same, please let me know.
Thank you.
Thank you.
If you are willing to install the Skype application for a Business client, follow these steps below:
If you want to install Skype, you need to make sure first your computer meets the requirements. Skype for Windows supports Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. Visit Skype for Windows to get the latest version. This downloads the full offline installer on your computer. Just run the installer once it’s downloaded to install Skype.
For users with Mac, Skype for Mac supports OS X 10.6 Snow Leopard and higher. This is the lowest possible version supported by Skype. If you want to install the latest, Skype for Mac version 7 and above, you need at least OS X 10.9 Mavericks or higher. Go to Skype for Mac to get the latest version for Mac.
To get a much detailed information about Skype’s specifications, visit Skype System Requirements.
