G.Adam
10 points
Posted on - 09/09/2016
Hi. I am not very familiar with the concept of RDP thin client OS. However, I would like to know the steps for connecting the RDP client to the serer. Please reply ASAP. Thanks in advance.
Learn About The Steps To Connect RDP Thin Client Osto A Server
Hi. To learn about the steps for RDP thin client OS, first log on to the server as the administrator by clicking on start, all programs, administrative tools, terminal services configuration so that the terminal service is invoked. Then, select Properties after right-clicking on the RDP-TCP connection.
Then click on the client settings tab. Next, update the configuration by clicking on the apply option. To redirect the communication port, configure the client separately. For example, select the configure option to set up an RDP connection in case there is no connection already existing. Then, click on the RDP connection and select the edit option after which you need to make sure that the check box for the serial ports is selected. Then, towards the end, verify that the server and client configuration is successful.
Hope we helped.
