Learn About The Error Code 2000- 0333
Hi, yesterday when I was playing the game on my Dell laptop then there is a sudden error is shown called Error code 2000- 0333. Do you know this error?
Error code 2000-0333, generally arise when there is a problem on Motherboard or Graphic card test failure.
In Dell computers, error code “0333” means you started the diagnostic tool or was launched automatically then on the part where you are prompted to hit “Y” when the test shows some color bars, you didn’t responded within the time allowed. This is actually not an error to get worried about because it is just an error with the test and nothing serious.
To fix the problem, just repeat the test and respond within the time required. Start your computer then press F12 when you see the Dell logo to start the PSA Diagnostics. On the menu, scroll down and select “Diagnostics” then hit Enter to start the PSA test. Follow the instructions on the screen and respond as fast as you can to complete the test.
