nood geroo
40 points
Posted on - 09/29/2017
It now happens to me every time that whenever I try to send some email it comes back with a fatal error called the following addresses had permanent fatal errors. As I don’t how to solve this issue please help me out.
Learn About The Following Addresses Had Permanent Fatal Errors Solution.
This type of fatal errors are faced by a large number of people. Here are the following ways to solve the problem. First way to solve this type problem is to try troubleshooting the issue and see to it whether it helps. Also try undoing all changes made (if possible) before you received such an error. Try even restarting your computer. Try scanning for viruses using online scanners and check if malware or virus is found. Use different links to run these scans. Hope this helps.
When sending an email using an email client like Microsoft Office Outlook or just sending from a browser, if the message you sent bounced back with an error saying the email addresses had permanent fatal error, that means those email addresses to whom you sent the message to don’t exist. This can happen if the email addresses are typed incorrectly or misspelled.
If you know those addresses are still active, check their spelling. An email address cannot contain a single incorrect character. Because if you accidentally inserted a wrong character in the email address, the message will go nowhere. And if a message doesn’t have a matching address to go to, it will just bounce back to the mail server and then back to you.
