Learn About The Siebel Error Codes And Their Solutions.
Hi. While generating a few log files, I have noticed the Siebel error codes on its application. How to fix them? Hope you reply to the earliest.
Hi. Siebel error codes are xxx-xxx-nnnnn and internal errors. An error like SBL-UIF-00401 may occur due to the Applet misconfiguration, which leads to improper execution of SQL queries. It is solved by the correct viewing of configuration and by setting the Applet property correctly. The view objects should have the appropriate values after reconfiguration. Different types of Siebel errors have different codes which differ in last five digits. These errors are avoided by checking the properties of Applet.
