Learn About The Sign In Messenger Facebook In Brief.
There is a simple method of logging out of your Facebook account while using messenger.
Just follow these steps to do the same:
Click SETTINGS, then PRIVACY & TERMS and then select MORE RESOURCES. Now, click PLATFORM, then ZOOM IN and select YOUR PROFILE ON RIGHT SIDE OF PAGE. Next, select LOG OUT. Again, GO TO SETTINGS, and this time, it should say something as, SESSION LOG OUT, and that you must LOG BACK IN!
If your Facebook account is logged in on many of your mobile devices, you can always log out a particular device from your Facebook account using a desktop computer. All devices that log in and accesses your Facebook account is listed on your account. These devices remain logged in to your account until you log out that device.
To log out a particular device from your account, on a computer, log in to your Facebook account. Once you are logged in, click the down arrow on the upper right corner of the screen then select “Settings” or just click this link: Facebook account settings.
On the next screen, click “Security and Login” on the left pane. On the right, under “Where You’re Logged In” section, click “See More” to expand the list of devices.
Click “See More” to expand
After this, locate the device you want to log out from your account then click the three dots next to it to see the options and then select “Log Out”.
1....
