Learn About Win32 Error Code 1722 Correction.
I got an error called win32 error code 1722 while opening and printing. Can you help me fixing this as I am new in the computer field? Reply ASAP.
This type of error is caused due to disabling of windows print spooler service. Because of this error one would not be able to print anything. This can be fixed. Try restarting your computer. Press windows + R key from your keyboard. In the run dialog box type services.msc and continue by clicking on various ok options. Then right click on Print Spooler to open properties. Click on Startup Type box and choose Automatic. Then choose the Start button under Service Status and click on OK. Your problem is solved.
