Learn About Window Blue Screen Error Code And Its Causes.
Every time I open my computer I get this blue screen with an error showing window blue screen error code. How do I fix this? Reply ASAP as I urgently need my laptop to get fixed
This type of error is also called blue screen of death or BSOD. Tryusing System Restore to solve this. Once you select the restore point, your system will restore process. After this restart the system. If this doesn’t fix the problem, then check for memory problems. Memory management issues can cause BSOD. Memory Management tool detects and solves problems concerning system memory. From taskbar select Windows Memory Diagnostic Tool. Restart, follow some instructions and check for problems. If problem persists thengo for unsupported devices removal. Uninstallhardware with causes this problem. You can detect such hardware using the device manager.
