Learn About Windows 7 Error 0xc00000e9 In Brief.
I am willing to ask regarding windows 7 error 0xc00000e9. If any person have any clue about this, please reply as soon as possible.
This bug is sometimes a hint that the hard drive might be failing. Perform the below steps to verify the integrity of your hard drive. In case you are not able to reach the menu Advanced Boot Option by use of the F8 key, then you will require obtaining a Windows Vista disc.
Once you can start Windows, remember to backup all of your important content.
Do let me know if this helps.
If you encounter error “0xc00000e9,” first, try disconnecting all peripherals from your computer including external devices like external hard drive, USB flash drive, printer, mouse, keyboard, and others. The only thing needed is the monitor plugged on the CPU to see the status on the screen. With all the peripherals disconnected, start your computer and see what the status on the screen displays.
If you see no error, try connecting all peripherals one at a time beginning with the keyboard. Turn off the CPU and connect the keyboard and then start the CPU again. Keep doing this until all peripherals are connected back. If the error appeared after connecting one of the peripherals, turn off the CPU and disconnect that device. Try connecting it on a different computer.
If it is working there, it is probably not compatible with your computer. This is probably the simplest way to diagnose the problem and find out which device is causing it. On the other hand, if the problem continues even after disconnecting all devices, it can be your hard drive that’s causing the problem.
You probably need to replace your hard drive at this point because it is probably failing.
