Learn About Windows Server 2012 R2 Pki In Brief.
I just have a small query about windows server 2012 r2 pki. If any person knows about this, then please share your knowledge on the same.
Thank you.
Thank you.
There are a lot of reasons to implement your public key infrastructure. If you are trying to set up Direct Access, in some conditions, for instance, when you wish Windows 7 users to use corporate resources via Direct Access – then you must deploy an enterprise PKI. The implementation of PKI by Microsoft has a name as Active Directory Certificate Services, and it appears built into the operating system of Windows Server 2012 R2.
You require considering your company’s security trends and methods before propping up an example of AD CS
