Elaine Vera
Posted on - 03/27/2017
Today when I tought of seeing what was not installing in my windows, I searched and got an update. The installation process worked but I then got an error called windows update code 670 and it has something to do with Silverlight. Help me out.
Learn About Windows Update Error Code 670 And Correction.
First try troubleshooting your problem. Undo all the changes you did. If this doesn’t help then you can solve this problem by uninstalling Silverlight using revo uninstall advance option. If this doesn’t work and silverlight uninstall fails again, use the advanced scan in Revo using which it will find all the left over registry entries delete them. This will help in allowing you to start from sratch and install the Silverlight. You can then run windows update correctly and the error will be solved. Hope this helps.
