Learn About Windows Update Error Code 800705b4 And Its How To Fix It.
I have been getting this one error called windows update error code 800705b4 whenever I try to install some updates in my computer. The notification also says that my computer won’t run properly without installing these updates. Help?
Answered By 0 points N/A #293577
Follow these steps to fix the error. Undo all the changes made before getting this error. Perform a clean boot for your computer and wait for it to run updates. Restart windows update service afterrunning the windows update troubleshooter. Restart the windows update service by typing the required commands and wait for the conformation. Try upgrading the windows build. If this doesn’t work then try manually upgrading windows. Hope this helps.
