How do I build a virus simulation attack program on my PC? I would like to learn how these viruses operate on my PC, therefore protect my computer from future harmful attacks. The program should enable me to practice virus infections& recover from them, hence attack them before they reproduce on my system. Any one familiar with simulation of a virus attack?
Learn how to build virus simulation attacks on my PC?
Antivirus practice lab is a software that is used to simulate a virus infection on your PC. As more you use this software it shows the virus infection by simulation. It can be used by the IT professionals to get trained by the virus effects in form of simulation. Before installing this software first install an antivirus utility so it should evaluate it. You can download Antivirus practice lab from following link.
http://ftp.pcworld.com/pub/new/utilities/antivirus/avpl.exe
A virus is a program that attaches it’s self with a file or program and acts like a worm in a computer it further creates its copies and then case the purpose that it is design for, may be it is designed to damage some data from your computer or it can take some sensitive data from your computer also.
Smith Thompson.
