Learn How To Convert Txt To Xml In A Few Simple Steps
Hi. I am working in an IT firm. I have a subject named Service Oriented Architecture due to which I have been coming across a number of XML files. Can you please tell me how to convert txt to XML? It will be helpful. Thanks in advance. Please reply ASAP.
Answered By 25 points N/A #93127
Hi, to learn how to convert txt to XML, first download the Stylus Studio. Then, select the file menu, click on new option and then convert to XML. Then, we need to select the input file which is to be converted to XML format by browsing it and pasting its location in the space provided. Next, after the file opens, the properties window can be opened after which the width can be manually set. On the first character of each field, right-click on it and select the option begin field in this column to set the boundary of each field. Give names to the fields after which the adapter can be run. Select the option convert to XML and then click on save option.
The second method of doing this can be by selecting any cell from the table created in MS-Excel. From the Add-ins tab in the menu commands group, click on XML tools following which select the create XSD files for the XML schema at the active cell. By selecting this option, all the content from XML will be pasted in the notepad. Select the file menu and then select the save as option from the notepad. Type the file name with .XSD format and click on the save button.
Hope we helped.
