Noah Baker
25 points
Posted on - 09/18/2016
Hi. I am a student. I have a project in the computer subject which includes learning about how to create organizational chart in Excel and implement it as well. I need to submit it ASAP. Can you please help me with the same? Thanks in advance.
V Gilden
10 points
Learn How To Create Organizational Chart In Excel Easily
Hi. To know how to create organizational chart in Excel, first open click on start and then click on MS-Excel from all programs. Then, either open a new worksheet or open an existing one to which the chart is to be added. Next, click on Insert menu and then click on SmartArt. Then, click on hierarchy when a graphic window to choose the SmartArt appears. From the designs which appear, select the one you desire and then click on OK. The blank chart which you just selected will be added to the worksheet. In the text box which is shown in the boxes, type the name of the employees. More shapes can be added as well if you right-click on the shape and select the Add shape option.
The shapes can be added before and after the boxes as well. A box can be added below the existing level by clicking on the Add an assistant option. Pictures can be added as well by browsing from the PC and opening the Insert Picture dialog box. Finally, select the image and click on the Insert option. Then, save the worksheet by clicking on file and then save.
Hope we helped.
