F Samuel
10 points
Posted on - 08/05/2016
Hi. I am figuring out a way to set up internet on my Xbox but I cannot find a way. Can you please help me by letting me know the steps so as to learn how do I get internet on my Xbox 360? Thanks in advance. Please reply ASAP.
To Learn How Do I Get Internet On My Xbox 360
Hi. The steps to learn how do I get internet on my Xbox 360are as follows-
1) Click on settings and then click on system
2) Click on network settings
3) Then select the name of the wireless network, configure the network, scan the network, enter the password and then click on OK
4) If you want to update the software, click on yes
To set up the network manually,
1) Click on settings then click on system settings and then press the guide button
3) Select the wired network
4) Click on configure network
5) Click on IP settings from the basic settings option
6) Select the IP address from the manual option
7) Type the IP address as 192.168.0.2 and then click on done
8) Click on subnet mask and then type 255.255.255.0 and then click on done
9) Click on gateway, then type 192.168.0.1 and then click on done
10) Select the DNS settings from the basic settings option
11) Click on manual and then click on primary DNS server
12) Type 192.168.0.1 and then click on done
13) Click on done one more time
14) On your controller, click on the B button and then click on Test Xbox live connection
Hope we helped.
