Learn How To Extract Pst From Edb
Hi. I want to learn the steps to extract pst from edb. Is there any way we can do it online? What is the need of extracting pst? Thanks in advance.
Hi. There is a need to extract the pst so as that the mailbox items can be restored, the market price of which is high. The Veeam Explorer can be used to do this. The steps to extract pst from edb are as follows-
1) First, the Veeam software should be installed successfully and run on the OS
2) Then, a VeeamZIP back-up which is a back-up of all the images is taken from which the restore can be done
3) Click on start and from the Veeam folder, click on launch Veeam Explorer for Windows exchange
4) Now the Veeam Explorer needs to be configured. Click on menu>Options>Specify path used to query the Exchange
5) The exchange files then need to be extracted from the backup to another file. This can be done by clicking on add store and then specifying the paths to the restored exchange database
6) From the options available when the Exchange database appears you can either export the .pst files, save the .msg files or send items as attachments in the e-mail.
All these features and options are available free of cost.
Hope we helped.
Notifications
