Learn how to install fax software for Windows 7
Hi.
I want to install the fax software for Windows 7. What are the steps for the installation? Also, could you tell me the steps for Windows Vista as well? I have no idea about the concept so it will be great if you could help me with the same. Thanks in advance.
Answered By 590495 points N/A #93767
Hi. The steps to install the fax software for Windows 7 are as follows-
1) Click on start, then select programs
2) Click on programs and features
3) Select the option Turn Windows features on or off
4) In the print and document services, click on Windows fax and scan and select the option
5) Click on OK
The steps to install the fax software for Windows Vista are-
4) Select the option of Windows fax and scan option when the Windows dialog box appears
5) Click on OK
Hope we helped.
