Learn How To Install The Free AS2 Software
Hi. I do not have a technical background at all. I would like to know how to download the free AS2 software? Please reply ASAP. Thanks in advance
Hi. To download the free AS2 software, first set the security permission for the MDN folders by clicking on properties and then from the security tab, click on edit and in the Permissions box, click on add. Next, enter everyone in the object names field and then click on OK.
Check the box next to write and then click on OK.
For the installation, first open the Windows Explorer and create a temporary files folder. Next, name the folder. After this, click on the link to begin the download. Save the file to the hard drive and then open it by clicking on it twice. Next, select the save option. Install the software after its download gets over and close all the software which are running. After the software is installed successfully by following the steps which appear, delete the file which you stored in the hard drive to free up that space.
Hope we helped.
