Learn how to make an Adobe form fillable in some simple steps
Hi. I am not very familiar with computers. I want to convert a form which already exists to a fillable PDF. How to make an Adobe form fillable? Please reply ASAP. Thanks in advance.
Hi. To learn how to make an Adobe form fillable, first click on the file which needs to be converted and then download the files or use a form of your own. Then, open Acrobat and click on tools. Next, search for the prepare form and open it to locate the file which needs to be converted to PDF. More than files can be converted including Word, Excel, scanned documents etc. After the file has been selected and opened, you can start preparing the form by clicking on the start option. Next, the properties of the text field need to be edited by right-clicking the text field and then selecting properties. Select options and then click on the combination of and type 2 there in the space provided. The check box needs to be modified next by right-click on the check box and then selecting properties. Next, select options from properties and make the box style to check. A signature field is added next by selecting digital signature from the tools menu. The text field can be extended as well by clicking and dragging it. A button to clear the data must be created as well by selecting the button option from tools. After the form has been created, review the form and edit it. Next, save it to a desired location where it can easily be accessed. Hope we helped.
Notifications
