Learn how to make a slideshow on Windows using few simple steps
Hi. I am not very familiar with computers. I want to make a slideshow. How to make a slideshow on Windows? Please reply ASAP. Thanks in advance.
Hi. To learn how to make a slideshow on Windows, you can use an application which helps prepare free slideshows in Windows 7. The name of the application is Ezvid. First, the software needs to be downloaded from its website which s Ezvid.com and then clicking on the free download button. After the installation is done, double-click on the file to open it and then follow the instructions displayed on the screen to install the software successfully. Then, click on the icon of Ezvid which appears on the desktop. Text, pictures and music too can be added to the slideshow with the help of Ezvid. If all these entire media needs to be added, click on the icon of Add media so as to facilitate this. The pictures can either be dragged to the Window or can be added serially. The slides can be added as well by selecting the T icon and formatting can be done too. After you are done, select the finish option. The pictures can be re-arranged as well. The option of recording voice helps us to add commentary to the video. The song of your choice can be selected from the drop-down menu which appears. A title and keyword must be added to the video as well and the video must be previewed as well by clicking on the play button. After the video is ready, it can be posted to YouTube as well by selecting the option of uploading to YouTube. Hope we helped.
