Learn How To Manage Tasks In Outlook To Delegate Tasks
Hi. I am totally new to MS-Outlook. I want to learn how to delegate tasks in simple steps. How to manage tasks in Outlook? Please reply ASAP. Thanks in advance.
Hi. To know how to manage tasks in Outlook to learn delegation of tasks, first open MS-Outlook from the start menu and then clicking on all programs. Then, to open the workspace of tasks, click on the link named tasks. Open a new task by selecting its button and then double-click the task which needs to be delegated if at all it already exists. Then, assign the task and it needs to be noted that the assignment is taking place in the task window and not on the main screen of MS-Outlook. Next, in the To field, the recipient’s name should be mentioned to whom the task should be assigned and instead of a name, the entire e-mail address can be typed as well.
The name of the task needs to be entered in the subject box following which it’s beginning and ending dates need to be specified as well. Information such as priority, report of the status, description of task can be added additionally as well. To finally delegate the task, select the send button and then verify that the e-mail has successfully been sent.
Hope we helped.
