Learn How To Read SD Card Using Some Simple Steps
Hi. I am not very familiar with the computers and mobile phones. I want to learn how to turn the SD card on and how to read it. Also, I need to know how to move applications to the SD card. How to read SD card? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #200429
Hi. To know how to read SD card, first, let us learn how we can start using the SD card after it has been inserted in the phone. After the insertion, a notification appears on the screen from which the option to set up needs to be selected. Next, select the internal storage following which you need to follow the instructions to finish installing the SD card. After the process gets completed, click on done.
Next, to learn how to move apps to the SD card to release the internal memory, first, click on settings and then apps from the device. Select the app which is to be moved to the SD card. Click on storage and then change. Select the SD card from the options which appear and follow the instructions which appear to move the app successfully to your SD card.
Hope we helped.
