Learn How To Save Passwords On Firefox In Some Simple Steps
Hi. I am not very familiar with Firefox because I have started using it recently. How to save passwords on Firefox? Please reply ASAP. Thanks in advance.
Hi. To learn how to save passwords on Firefox, first, click on the menu button and then select on options. Click on the security panel and mark the option for remembering the passwords for the sites. Then, select exceptions and ensure that the site you are logging in to is not present in the list and if at all it is, then, remove the entry. Changes made will be saved after you close the preferences page.
To save the password on Firefox, select remember so that the next time it automatically enters the username and password for that particular site. In case, the password is to be modified, click on update. Never remember the password for this site in case the password is to be saved for the current site. In case the password and username should not be saved for the current site, select the not now option and the next time you visit that website, the username and password can be saved as per your wish.
Hope we helped.
