Leah James
Posted on - 06/03/2020
I have to create a virtual network, but I’m facing many problems in creating it. So many issues are coming in my way while creating it. So, I want a proper procedure to create a virtual network? Thank you!
Learn how to Configure a Virtual Network.
Hello. The use of a virtual network is to enable a data center to provide the most suitable and efficient networking structure for the applications it also hosts to alter that structure as conditions warrant, using software rather than requiring physical changes in connections to hardware. For creating a virtual network, firstly sign in to the Azure Portal. After signing in follow the given steps:
Step 1- Firstly, from the Azure portal menu, click on Create a resource. Select Networking -> Virtual network, from the Azure Marketplace.
Step 2- Now, In Create virtual network, enter your information.
Step 3- Then, click on Next: IP Addresses, and in the IPv4 address space, enter 10.1.0.0/16.
Step 4- After that, select Add subnet, then enter myVirtualSubnet for the Subnet name and 10.1.0.0/24 for the Subnet address range.
Step 5- In last, click on Add, then select Review + create. Leave the rest as default.
Step 6- Create a virtual network, select Create.
