Learn How To Create A Microsoft Word Fax Cover Sheet.
Hi, I am a beginner of MS office, can you help me to create a Microsoft Word fax cover sheet in MS Word 2007. Thank you in advance.
Hello, to create a Microsoft Word fax cover sheet, you need to open ms word and the click on a new option in the menu bar, then you will find many templates, search for fax cover templates and then click on it to open. You will find many formats of fax covers, choose your fax cover of your choice and then click on ok.
Enter the details on your fax and then go for review for any spelling errors and then save and print it. Like this you will create a fax cover sheet in ms word. Below you will find the image of a sample fax cover sheet.
