Learn How To Fix If ‘My Computer Keeps Saying Not Responding’.
Hi, my computer keeps saying not responding , will you help me how to fix this problem. Reply me ASAP. Thanks in advance.
Hi, if the issue of ‘my computer keeps saying not responding’ to fix this kind of issue, force shutdown your PC and start up. And the another thing you need to do is scan virus on your computer and remove the virus from your computer. And in case, if you upgraded from other versions, make sure that all the requirements were fulfilled. And you can also reinstall your operation system. And the easy way to fix this issue is download ‘Regcure’ application in your PC which fixes all the issues on your computer.
