Learn How To Fix Playstation Error 80710102 In Brief.
Hi all,
I am using PS3, but I am worried about the playstation error 80710102 as it keeps popping on the screen whenever I turn it on.
Can someone help me in resolving this issue?
Thank you.
Hi all,
Thank you.
Step 1:
First, open a web browser and enter your IP address in the URL address bar.
Step 2:
Now, just enter your credentials to access the router. Then press OK to see console application.
Step 3:
After that, click the “Password” tab.
Step 4:
In this tab, you will notice UPnP settings under the router’s password settings option.
Step 5:
Now, select Disable under the UPnP box and click Save.
Step 6:
Now, close your console of the router and then restart your PS. Now, connect your play station to the internet.
