Learn How To Fix QuickBooks Error 80029c4a Instantly
Hello all,
Whenever I click on the quick book icon on my desktop, it shows the QuickBooks error 80029c4a.
Can anyone, please, tell me how to fix this issue?
Hello all,
To fix this problem try reinstalling QuickBooks. After that, open QuickBooks and check if it still gives you the same error. If you don’t get the error this time, all you need to do is re-browse your company file so that you can continue to work again. Follow these steps to re-browse:
• First, open QuickBooks and then click on Open or restore an existing company, after that, select Open a company file and then click Next.
• On the window that appears, locate your file using the same location where you saved it earlier.
• After finding the file, highlight it and click on Open button.
• It will now successfully show up the login screen.
