Learn How To Fix The Issue ‘My Computer Screen Is In Sideway’.
Hi, ‘my computer screen is in sideway’, am not getting to fix it, please help me to fix it. Thanks in advance.
Answered By 20 points N/A #280083
Hi, if you have the issue ‘my computer screen is in sideway’, you need to do a simple job to turn it back.
google
Press ctrl and atl and up arrow key at a time in your keyboard ( ctrl + atl+upward arrow key)Then your screen will be in proper direction. Simillay you can change your screen direction with using different arrow symbols.
keys
